Use the following procedure to configure a collector for IPFIX. Use the ExtremeAnalytics™ solution as the collector.
You can configure IPFIX on Segmented Management Instance interfaces VLAN and CLIP. You can also use routing VLANs or loopback IPs as the exporter IP address. Configure the exporter IP address to match the Management Instance interface IP address.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#ip ipfix collector 1 192.0.2.15 exporter-ip 192.0.2.16 dest-port 2 src-port 4 Switch:1(config)#ip ipfix collector 1 export-interval 40 Switch:1(config)#ip ipfix collector 1 initial-burst 4
Use the data in the following table to use the ip ipfix collector command.
Variable |
Value |
<1–1> |
Specifies the IPFIX collector ID. |
{A.B.C.D} |
Specifies the IP address of the collector. |
exporter-ip {A.B.C.D} |
Specifies the IP address of the exporter. Note:
For Segmented Management Instance interfaces, the exporter-IP address is the IP address of the Segmented Management Instance interface on which datagrams egress. |
dest-port <1-65535> |
Specifies the destination port receiving flow information. |
src-port <1-65535> |
Specifies the source port sending flow information. |
export-interval |
Specifies, in seconds, the frequency of template packet exports to the collector. The default value is 60 seconds. |
initial-burst |
Specifies the number of template packets sent when the collector becomes reachable. The default value is 5. |
